Belly-Mount Weight Bracket
Tye
03-12-2004 20:00:40
If anyone has a picture or two of their belly-mount weight bracket on their hard drive and doesn't mind sending it to me- please I could really use a picture. Thank you. Have a great evening. --Tye [email protected]
720Deere
03-13-2004 14:22:00
 Re: Belly-Mount Weight Bracket in reply to Tye, 03-12-2004 20:00:40
Hey Tye,
Have any luck with the wheel weights yet? I don't have anything on the belly mount, but I will send you some pictures of the side mount brackets that we are using.
We use 6" heavy wall tubing welded to a flat plate that bolts right to the frame with I believe 3 bolts.
We cut a hole in the top of the tubing to hang the weights on. The bracket is welded up with a slight tilt so the weight hangs against the tubing tightly. These are lighter than the belly mount types that I have seen and look a lot better too!
