Engine oil for Model 60
Chris in SWMO
03-12-2004 19:33:07
I was wondering if Rotella 15-40 would be to heavy of an oil to run in the model 60. It is mainly used for light duty jobs. The previous owner said that was what he always used in it. He also put it in the hydraulic system. I hope that won't cause me any troubles. Thanks in advance for your replies. Chris in SWMO
F-I-T
03-13-2004 08:02:33
 Re: Engine oil for Model 60 in reply to Chris in SWMO, 03-12-2004 19:33:07
Chris:
Motor oil is a very personal subject. What one person uses just would not do for another. Anyway, here's my take.
I have a '70' Diesel, an 855, and a little VAC Case - Gas. I use Rotella in all of them and in my cars. The weight and grade seem to fit the span of temperatures I experience in North Florida so I can use it year round.
As far as the Powr-Trol hydraulic system on your '60', the manual calls out to use the same weight of motor oil in it that you are currently using in the engine. So, yes the Rotella would work just fine. Nowe some folks claim that detergent oils tend to foam, so they recommend using non-detergent oil in the Powr-trol. Others that share hydraulic cylinders with more modern equipment, use JD 303 or I guess it's called Hy-Gard these days, without any trouble.
I use extremely cheap non-detergent oil because all I need is a good clean oil. I had rebuilt/resealed most of the system, and there is little, if any dirt in there, so non-detergent is cheaper and will work for me just fine.
Unless you have a lot of leakage, fill it with whatever you have and it will likely operate just fine. Those old Powr-Trol units are pretty forgiving.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
rla
03-12-2004 19:42:13
That engine oil will do just fine, but I would question it in the hydrallic's?
