720 Idlergear
Russ
03-12-2004 18:56:37
Ihave a 720 diesel.The idlergear between the cam and the crankshaft has a lot of play.I have another one out of a 730.What I noticed was the part number out of my parts book is diffrent.I know a 730 gear will work but the gear I got out of my tractor is F1902r f1901r.Does anybody know what this gear came out of. This tractor was running when I bought it.Thanks Russ
Clooney
03-12-2004 19:38:20
 Re: 720 Idlergear in reply to Russ, 03-12-2004 18:56:37
Russ, the number in the parts book is the assembly number, the number on the gear is the casting number.. I don't have anything that shows the casting number on that 730D idler gear.. The later [730] idler gear also uses the later shaft with the center bolt in it.. The earlier 720D idler gear uses the snap ring shaft.. The late gear might work on the early snap ring shaft but I haven't ever tried as I always use the later center bolt shaft...
[email protected]
Russ
03-13-2004 05:47:36
 Re: Re: 720 Idlergear in reply to Clooney , 03-12-2004 19:38:20
Thanks Clooney I will have to see what my parts guy sends me. THANKS agin Russ
