4020 pto drags
Wayne
03-11-2004 22:44:25
first, thanks to all for the powershift advise. i bought the tractor. in the process of fixing those issues, but found another. the pto spins continuously under no load. didn't worry to much about this until i hooked my flail mower on for a test run. with the shaft connected the pto did not spin immediately, but after about a minute with engine running, pto began to spin the mower slowly. dangerous! anyone familiar with this?
Brokenwrench
03-12-2004 15:05:44
 Re: 4020 pto drags in reply to Wayne, 03-11-2004 22:44:25
If it is not the linkage issue mentioned below,it could be a worn out pto brake and possibly warped pto clutch plates. When using pto equipment,alot of operaters just pull the pto lever back and let it snap down which applies the pto brake. The pto brake is not alot bigger than a pack of matches,and it doesn't take long to wear it out when not used properly. It is made to hold the pto from turning,not stopping the rotating mass of a feed grinder,big rotary mower or baler. Replacing it requires splitting the tractor at the trans/rear end flange.Probably not what you wanted to hear.
51 A
03-12-2004 07:25:55
Most likely you have a sheared roll pin and to fix this problem will require splitting the tractor.
david val
03-11-2004 23:51:14
remove the panel under the steering coloumn and watch the pto linkage. there is a lever connected to a shaft coming out of the pto valve , that is held with a 1/4 inch nut and a washer (sometimes that area is filled with dirt and some cleaning is requires). if you see or feel play between the lever and the shaft when moving the pto lever on the dash, replace the lever. a vey common cause for pto problems on theese tractors.
david
