6030 pro's con's
Sponz
03-11-2004 20:50:51
What were the good and bad points of a 6030?
I mean engine, drive terrain, cabs, and relaibility. thanks for any input
Markie
03-12-2004 01:07:55
 Re: 6030 pro's con's in reply to Sponz, 03-11-2004 20:50:51
I own a 1974 row-crop without cab. I've bought her 2 month ago. I've checked the engine by listening and see if she had any leaks.
The transmission clutch is easy to check. Drive aroud and you know how she picks up gears. The clutch can be checked by removing the cover underneath and have a look with a flashlight.
The pto-clutch is difficult to check...
Engine parts are still availble from Deere. Sheetmetal isn't. That's only availble from salvage-yards. Prices can be high.
I'm not an expert or so. I'm only telling what I did.
Hope this helps...
Would be nice if you inform us on how it went.
Greetings Mark
Farmer J
03-12-2004 06:24:33
 Re: Re: 6030 pro's con's in reply to Markie, 03-12-2004 01:07:55
THESE tractors usually had major rear end problems- about every 2000 hrs you were due to break it in half and work on the tranny(to much hp and not enough iron in the pants) Ask anybody thats owned one- they know.
G-MAN
03-12-2004 07:46:13
 Re: Re: Re: 6030 pro's con's in reply to Farmer J, 03-12-2004 06:24:33
That's bunk. I have a buddy who was farming with three of them, pulling big equipment in wheat country, and didn't have problems with anything behind the engines. He did have an engine go down once, but that was on a freshly-purchased tractor with a questionable history. The 6030 powertrain was built extremely strong. I frequently see one pull in an 18,500 class, and he'll have the front wheels 4 or 5 feet off the ground at the end of the track as he takes the sled out the gate. If something was going to fail, it would do it then.
JDKIA
03-12-2004 19:45:18
 Re: Re: Re: Re: 6030 pro's con's in reply to G-MAN, 03-12-2004 07:46:13
the fore runner of the 6030(the 5020) was a very rugged tractor that was used quite successfully in the abrasive soils of the Miss. River Delta. When the 6030 came out it was mostly the same except for the option of two different engines, the smaller one was the same as in the 5020, but the larger one was turbocharged.
Jack
03-12-2004 14:56:08
Been told lots of things that were bull in the past but I know a guy that had one for years and it was one heck of a HOSS.His was turned up and at night working it was a light show at the end of the stack.His never did give him any problem even with some extra ponies turned on it.He had mentioned that the rear end was very much like the ones that the 4wheel drives had and just as big and at the time a 6030 was the biggest 2wd you could get.It was one tough lookin machine with those 30.5's on it back when he was pulling it,said they weren't worth a dern in the field though.
John Jenkins
03-12-2004 15:31:15
 Re: Re: Re: Re: Re: 6030 pro's con's in reply to Jack, 03-12-2004 14:56:08
Ours 6030s both have long axles and hub-mounted cast duals (18.4-38s on one and 20.8x38 R&C on the other). They both pull like h&ll. I actually broke a quick hitch in half one day pulling a 9-shank subsoiler in clay with the 6030 on 18.4s!
Mopower
03-12-2004 11:18:35
I could have been mistaken, but maybe the 5020 had rear end trouble, not the 6030. Like I say, I am an MM guy and a little rusty on the newer Deere's.
Mopower
03-12-2004 11:05:27
I couldn't help but read the 6030 comments. I clicked on it because I knew they had a history of rear end problems. True some didn't, but not always due to lack of iron, but in the tranny design and bearings. Gears were plenty heavy. I'm an MM guy and G1000 were some of the worst offenders when it came to tranny. More motor than rear end. A G1000 can pull in heavy classes ripping and snorting, but put one in a field under heavy plowing and the rear end will go from the extended heat and pressure. Allis, Massey, Deere, and Oliver all had their models. Grandpa fixed the problem by dropping a bottom off his plow but I still think a tranny should take twice the power of the motor for long periods of time. That is why the G1000Vista was introduced. My 2 cents. The neighbors have a 6030. What a giant horse! I like it.
52 A
03-12-2004 07:28:43
I doubt your comments. That tranny and rearend was rated for over 300 hp. If you have neighbors with those problems, I would be very leary of their maintenace programs.
John Jenkins
03-12-2004 08:29:58
 Re: Re: Re: Re: 6030 pro's con's in reply to 52 A, 03-12-2004 07:28:43
I concur. Whoever is having to do a major overhaul on a 6030 rearend every 2000 hours is just not taking care of their machine. We have two of them ( row crop, turbo, synchro and 2-post ROPS) that both pull well over 220hp and have stayed together doing work in some cases that would be meant for a much bigger tractor. These old tractors are TOUGH! Of course you gotta be pretty tough yourself to run one as ours are hot, loud and love fuel. Especially in 95F/95% humidity Alabama summers. The 6030 is probably one of the top tractors to buy for reliability and cheap horsepower.
Greengo
03-12-2004 12:28:28
 Re: Re: Re: Re: Re: 6030 pro's con's in reply to John Jenkins, 03-12-2004 08:29:58
I know a guy that is pulling one in Super Farm
and was running over 700 horse. Been pulling
it for around eight years and never had any
trans/diff problems.
Sam Bezner
03-12-2004 15:30:39
 Re: Re: Re: Re: Re: Re: 6030 pro's con's in reply to Greengo, 03-12-2004 12:28:28
I help my dad farm and he has a 1974 row-crop turbo 6030.We pull a 30'chisel plow in 5th gear with no problems and drop it to 4th for deep plowing.The one problem is that it really likes to drink fuel,but we have never had a problem with the rear-end in the 8 years we have had it.That one man was right though,we do not have a cab and at the end of the day you are various shades of earth and it takes about 30 minutes for your hearing to come back,but we like it.It is very reliable and highly recommend buying one.The JD's with rear end trouble are the 4520-4620,too much motor not enough metal
travis
05-21-2004 14:11:17
 Re: Re: Re: Re: Re: Re: Re: 6030 pro's con's in reply to Sam Bezner, 03-12-2004 15:30:39
We have got a 6030, we call him the wooly mammoth. We bought it with the spider gears disentegrated. We don't work it hard, in fact 22 ft is our widest disk. My brother was pulling a tiny 10 ft rome disk when the geas either went out or posi-trac became stuck. He's currently parked under a lean-to awaiting surgery. Any tips on how to insure this is the last time?
