3-way fuel valve for unstyled B serial # 26,XXX
Wayne Swenson
03-11-2004 19:58:10
Anyone found a source of replacement valves? Or where to get a good original one?
Clooney
03-12-2004 03:14:17
 Re: 3-way fuel valve for unstyled B serial # 26,XX in reply to Wayne Swenson, 03-11-2004 19:58:10
Wayne, Roberts Carb now carries them.. They aren't cheap but he carries good stuff..
~You can rebuild yours if it's just leaking out the valve handle end.. There is just a cork type seal in there [available from Deere].. If it leaks around the valve barrel so it won't shut off properly you probably need a new valve..
[email protected]
