65 4020 Clutch problem, syncro range
Gary in TX
10-21-2003 13:27:27
Ok, here goes. I'm having problems with the clutch on a 65 model 4020. Pedal free play keeps going to almost 4 inches or more, I have adjusted it and it held a 3/4 or so free play for just a bit. Also lots of smoke out of the bell housing(but that has quit. Still moves around freely and seems to have plenty of pull too it. I'm assuming that the problem lies in the what would be callled a throw out bearing on a truck tranny. I'm thinking of trading it off for another tractor and have let the people know of the problem, not trying to hide anything here. Problem is the one I looked at would require more work than the one I have but it is a 4230 cab/air adn loader. the 4020 has a loader too by the way. Thanks
Gary in TX
10-25-2003 19:23:05
 Re: 65 4020 Clutch problem, syncro range in reply to Gary in TX, 10-21-2003 13:27:27
Thanks for the replies guys. I have made a deal to trade the 4020 in on a 4430 with a loader on it and I get to keep the 48 loader off of the 4020. will be nice having 2 loader tractors as I'm thinking of putting the 48 on my 3020 or my 4230 as both have dual hydraulics. For my needs I just can't justify spending 2 to 3000 bucks on the 4020 when I'm wanting to move up to cab tractors anyhow. I will miss the 4020 as it was the 2nd 4020 I have owned. I'm sure another will be in the future though.
MICHAEL
10-24-2003 23:27:10
HEY IF YOU WANT TO FIX YOUR 4020,LET ME KNOW.I BRING PARTS UP OUT OF MEXICO, WHERE THE PRICES ARE CHEAPER,(JUST LIKE MEDICINE),AND I HAVE A KIT ON HAND IN TEXAS THAT HAS PRESSURE PLATE,PTO & ENGINE DISC,THROW OUT ,PILOT,& PTO BEARINGS. GOOD LUCK
G-MAN
10-21-2003 13:51:59
Pull the inspection cover off the bottom of the clutch housing, grab a flashlight, and have a look. It should be readily apparent if the release bearing is the problem. Smoke from the clutch housing is never a good sign. Also check to make sure you're getting the clutch adjustment hardware good and tight. Post back with what you find.
