1959 John Deere Brakes
J.R. Dobyns
03-11-2004 15:12:54
I have a 730 and are redoing the brakes. I got the pads redone but I have misplaced the hardware to put everything back together with. The ajustment pins are also stuck in the cast housing. What is the easiest way to get the adjustment pins out and find a place to get the rest of the brake hardware?
Thanks,
J.R.
Clooney
03-11-2004 17:48:42
 Re: 1959 John Deere Brakes in reply to J.R. Dobyns, 03-11-2004 15:12:54
J.R., you ask..
~"What is the easiest way to get the adjustment pins out?"...>>> Answ, I usually use plenty of heat on the casting around the pins, then as it cools spray them with penetrating oil... Go at it easy as those adjusters twist off easily..
~"And find a place to get the rest of the brake hardware?"...>>> Answ, you can try Deere parts at your local dealer [Deere still carries most brake parts].. OR, try your local tractor scrap yard... OR, try some of the online tractor scrap yards.. OR, place a wanted ad in the Classified Ads on this site..
[email protected]
Mel in sw Iowa
03-12-2004 06:26:10
 Re: Re: 1959 John Deere Brakes in reply to Clooney , 03-11-2004 17:48:42
Clooney,
I'm not trying to sharpshoot one of your usual valuable first rate answers, but I think you should add the recommendation that he make sure that he is safely seated at the JD counter before he gets the price quotes on JD brake parts hardware.
Mel
