JD 4010 Rear tires
Kevin
03-11-2004 14:14:31
I have a JD 4010 with 15.5 x 38 rubber on 14 inch wide rims. I want to put 16.9 x 38 rubber on it. Can I mount 16.9's on the existing rims or do I need 15 inch wide rims? I have seen that most tire manufacturers say to mount them on 15 inch but I also have seen where it calls for 14 inch wide. I would like someone smarter than me on this to give their considered opinion.
Thanks!
Mike Aylward
03-11-2004 16:11:12
 Re: JD 4010 Rear tires in reply to Kevin, 03-11-2004 14:14:31
Kevin, while the preferred rims would be the 15" (or even 16") you can still get along mounting the tires on your 14" rims. The tread width of both the 15.5 and the 16.9's is nearly identical with the 16.9's having a taller sidewall. Your proposed switch has been done many times without problems. Hope this helps. Mike
Kevin
03-14-2004 07:17:25
 Re: Re: JD 4010 Rear tires in reply to Mike Aylward, 03-11-2004 16:11:12
Thanks Mike.
