jda shift pattern
big jugs
03-11-2004 06:56:51
Got a question...if you removed the shift quadrant housing and just left the shifter stick, would you be able to find all the gears ok yet, don't worry about why I want to do this, have ideas buzzing in the back of my head!
Clooney
03-11-2004 13:20:00
 Re: jda shift pattern in reply to big jugs, 03-11-2004 06:56:51
BJ, I presume you are talking about the later "A"?.. If so, the gears will still be available but without that quadrant to guide the shift lever it will be difficult to find the correct position of the lever to engage the gear you want... It will also try move 2 shift rails at once if you aren't real careful with the lever position.. If you are very careful & deliberate when shifting it should at least be drivable..
[email protected]
