Tyler, you say..� The exhaust is going out the intake and it's sucking in air through the muffler��>>> Answ, that sure sounds like you have a cam timing problem.. I�m not sure if you lined up the correct cam/crank marks.. Sure sounds like something is wrong.. ~You also ask��I noticed that from #1 TDC (all valves closed) that when rotating the crankshaft the exhaust valve on #1 (LH cyl when sitting on the tractor) opens first. The #1 piston was going back (like it would on combustion or intake stroke when the exhaust valve is open).Is this correct?��>>> Answ, yes, when rotating in running direction [from compression TDC] the exhaust would open first as the combustion gas would have to leave before the next intake & compression stroke. ~You also ask��Let's assume that the timing marks are lined up� Could the cam gear and cam shaft be out of time...there are 3 bolts that hold it together and they could have been out of whack to begin with (dumb me didn't make sure the timing marks were in alignment before I originally pulled the crank). Is there a timing mark on the cam shaft and cam gear that I could look and see if it is aligned up��>>>Answ, I doubt it, but you never know what a previous owner did.. ~You also ask�� I think I need to know the simplest way to time the valve train on the engine. Since I had no book for assembly I just lined up the marks like I have on other models��>>> Answ, there should be a some writing on the flywheel [I can�t remember if it�s on the flywheel face or rim on a 520].. That writing should say [L/H exhaust open].. First, make sure the flywheel is on the crankshaft correctly [flywheel slot will be running directly fore/aft with the L/H piston at TDC], then make sure the L/H exhaust valve lash is set correctly, then slowly rotate the flywheel in the running direction [top forward] & feel the L/H exhaust push rod, just as the L/H exhaust push rod starts to tighten up [right at 0 valve lash] the [L/H exhaust open] on the flywheel should line up with [or be within about 1" of] the case mark or timing mark on the case� I�ll have to look in the book later to be sure where the flywheel/cam timing marks are on the 520 as I haven�t done one in a few years.. Look back here later.. [email protected]
