JD 2840 hydraulics
Tom
03-10-2004 19:06:11
I am working on a 2840 that would loose the power steering with the pto running. Changed the transmission pump and now the hydraulics work better and faster, then with the pto running and working the loader the loader stops and will not go up or down and the power steering quits and the pto is still running. What is wrong now? Thought about adding more hydraulic oil thinking that the loader needs it. Any help would be appreciated. Thanks
cannonball
03-11-2004 05:58:14
 Re: JD 2840 hydraulics in reply to Tom, 03-10-2004 19:06:11
the 2840 has a pto shift down on side of trans housing..the tranmission pump supplies fluid to filter then pto first then to hi lo what they don't use it goes to front pump..the tube that breaks is after it goes to hi lo..had to replace tube in our 2840..replaced clutches and sealing rings in another 2840 pto..you have to split tractor at transmission...oh yes there is a coupling between pto clutch and pto shaft make sure that you do not let it fall into trans case..if you need any more information e-mail me..have nice day may god [email protected]
Tom leitch
10-10-2005 07:38:17
 Re: Re: JD 2840 hydraulics in reply to cannonball, 03-11-2004 05:58:14
I have the same problem with no hydraulics after about 30 minutes of running.I can shut the engine down and restart and everthing functions again for about 15 minutes and I start the same procedure again.What are my options if any. I have changed filter and screen at rear of tractor. PLease help!!! TOM
Adam
03-10-2004 22:09:48
Sounds like there is a major oil leak in the pto supply circuit. The pto will probably slip too if you put any load on it. If you remove the transmission top cover with the shift levers, there are two steel tubes that are for the pto clutch and brake. There will be four tubes if you have a hi-lo. Not sure which two are for the pto but you should have an I&T manual at least if you've put a trans. pump in, that should tell you which is which. Determine which tube is for the clutch and which is for the brake and apply some air pressure to them, one at a time. Most likely you will have an air leak on the pto clutch circuit and you might be able to see a mist of oil to see where the leak is. Sometimes the steel tubes crack and cause problems. I just rebuilt the hi-lo, pto and mfwd clutches on a 2840. Also rebuilt the hydraulic pump and checked out the transmission pump. Good luck with yours.
