JD 60 Reverse Only!!!
The Rodent
03-10-2004 18:57:29
I have just bought a JD 60, after I backed it off the trailer I noticed it that it was sticking into reaverse. What could be the trouble? Thanks
Chris
03-10-2004 19:09:02
 Re: JD 60 Reverse Only!!! in reply to The Rodent , 03-10-2004 18:57:29
I had one do that before. To fix it I had to remove the plate that the shift lever is running through and move the shifting plate around little. On mine the shifter would move but wouldn't shift gears. It had slipped out of the plate that shifts gears inside the transmission. You could try that or just mount a cotton picker on it and try not to have to back up HA HA. Let us know how it works out.
