JD 40 High Oil Pressure
JD40
03-10-2004 18:55:32
I recently replaced a non-working oil pressure gauge on my 40 and now show very high oil pressure. The gauge is a white faced JD gauge, and should have been a black faced gauge. There are only marks for low, normal and high pressure, no lbs ratings. Would the white face gauge reflect lower pressure ( for older tractors ) or could the pressure really be high. What would cause such high pressure?
Clooney
03-11-2004 03:38:41
 Re: JD 40 High Oil Pressure in reply to JD40, 03-10-2004 18:55:32
JD40, first test your gage at 30 psi to see where it reads.. To do that just hook it to a tire inflator end & check the air pressure in your tires after you use a known good tire gage to set them to 30 psi..
~Next, run that 40 under load for about an hour to thin the engine oil out real good, then see where it reads.. Those old 40's seldom read high on a hot working engine.. Your oil pressure is supposed to be taken on a hot [that's working hot] engine at rated RPM..
[email protected]
Jeff's40
03-10-2004 19:49:31
Yes it could be the new gauge, but with out knowing what the oil pressure is, it would be difficult to know. You should be able to find an oil pressure gauge, that shows the psi, from the auto parts store. According to the service manual you should have 30 psi + or - 5 psi at 1850 rpm. Of course that would be a new tractor.
Jeff
