4-bolt B fanshaft
TIMAR
03-10-2004 17:22:07
Have some ?'s about disassembly. It does not look like the parts breakdown I have on cd-rom. The one on the cd looks close to a 630 with the round clutch discs. Mine has some kind of rubber spring that is shaped somewhat like a football with the ends cut off. I can e-mail pics of it if that would help.
Clooney
03-11-2004 04:16:02
 Re: 4-bolt B fanshaft in reply to TIMAR, 03-10-2004 17:22:07
TIMAR, the fan you have is the original rubber hubbed fan.. Most of those have been replaced with the later friction clutch fan assemblies over the years [that�s what�s shown in the parts book] .. Those original rubber hubbed fans tended to get dry rot in the rubber & fail [in a lot of cases taking the radiator out with them]..
~Your rubber hubbed fan has a splined center in it that pushes on the fan shaft splines.. Those tend to rust on the splines over the years & are difficult to get off.. You can't use heat or you will ruin the rubber & it's hard to get a puller behind the fan as all that will do is pull the rubber apart.. Some penetrating oil on the splines [don't get in on the rubber] & tapping on it will in some cases help.. I have had some luck with pulling the fan shaft off the tractor, then driving the fan on a little farther, then pulling the keeper off the front, then tapping the front of the fan shaft on a piece of wood on the concrete floor.. If you work at it long enough it will eventually come off.. Be careful with that fan if it�s rubber is in good condition as those rubber center fans are very difficult to find.. If you ruin that original fan or pull the fan off the rubber center you will probably have to replace it with the later friction drive fan & related parts..
[email protected]
