4240 steering
Kevin wwright
03-09-2004 20:11:03
I have a 4240 that exhibits a slow creep of the front tires to the left while running. I suspect a problem in the steering valve or steering motor. Any info?
JDTECH
03-09-2004 21:17:52
 Re: 4240 steering in reply to Kevin wwright, 03-09-2004 20:11:03
The problem could be in either one. Have you had a problem with the steering metering pump (under the dash) blowing the hose off? The most common problem for this symptom is excessive internal leakage in the steering valve. You can check the amount of leakage past the steering valve (under the hood) by disconnecting the return hose where it connects to the clutch valve housing (behind front left cab mount). You will have to cap off the fitting where you removed the hose(If the fitting has a barbed end you will have to remove the fitting and plug the hole with an oring plug). Start the engine and run at 2000 rpms. Normal leakage is 1 pint in 1 minute. If you are having trouble with the steering darting one way or the other while driving, the problem is most likely in the steering motor (worn or damaged orings). If you have any questions please feel free to e-mail me. Good Luck!!!
