4010 idles but dies
Digger
03-09-2004 19:36:09
I just converted my 4010 LP over to gas, got a new 4020 carb on it started it up last night idles great give it gas she falls on her face and dies. Cheaked for vaccum leak around carb.and manifold no leaks.The fuel pump is working fine Was wondering if you all might have any anwsers.
Bob M
03-10-2004 09:47:09
 Re: 4010 idles but dies in reply to Digger, 03-09-2004 19:36:09
Digger - I've had similar problems on occasion with an Oliver 1850. I believe the Oliver uses the same Marvel-Schebler USX (die cast aluminum) carb as on the 4010. Things to check:
1 - The high speed mixture adustment is set too lean. Open it up 4 - 5 turns from closed and see if this helps.
2 - The fixed high speed metering orifice is plugged (it's inside the float bowl opposite the adjustable high speed orifice.)
3 - The USX has a vacuum actuated accelerator pump. If the pump is not working the engine will stumble and stall when the throttle is opened. And pump will not work if the diaphragm is is stiff (old age) or has a pinhole in it. The pump is located on the inside of the carb bowl cover.
Good luck!
