 es: It's kind of hard to tell from your picture, but could you take a grinding disk and clear that weld off the crank and off of the face of the gear? If you can, then you can remove the gear with a puller and save the gear that way. It's a lot of work just to replace a key. I have repaired these by (what follows is a non-approved JD service method) placing the thrust plate against the crank gear on the remnant of the key. Then slide the spacer onto the crank, and hold it right tight up against the thrust plate, then CAREFULLY orient the spacer rotationally so that the plate will interlock with the remnant of the key while the flywheel driving slot tang is located on the proper crankshaft slot to engage the flywheel. Now, tack weld the plate to the spacer right where they meet. Don't use too much heat because if you distort the plate, you'll have to true it up in a lathe or replace it. It won't take much tacking to create a good bond. You just need enough to keep the parts together, so that the flywheel can drive the plate instead of the key doing the work. Afterward, you'll need to check the plate/spacer assembly for runout, and correct it on a lathe or grinder if it warps. Then insert the inner thrust washer, then the plate/spacer assembly, then the outer thrust washer, then the shimpack, thrust spacer and thrust cover, set the endplay, and install the flywheel. It's a non-JD repair, but if it works (and it has not ever failed me), you saved the time and trouble of trying to remove the gear for that $.05 key, and if it fails, you're no worse off than you are right now If it fails, you'll have to pull the gear, grind the tack welds off your spacer, buy a new thrust plate ($60) and do it the book way. But....mine has been running really well this way, as well as several others. ;) Frank-in-Tallahassee [email protected]
