2010 Hydraulics Question
Dave / Believer
03-09-2004 13:17:49
I have a 1962 2010RU that I am trying to get the hydraulics to work properly.
The tractor: 2010RU with single rockshaft control and dual PTO. It looks like it may have had remote hydraulics added or at least the lines to the quick couplers added - they are a combination of steel and high pressure hose that run on top of the footboard to what looks like the incorrect quick couplers on the rear. It has a single control lever for the remote at the far left of the dash and a single control lever for the rockshafts. The control lever for the remote is disconnected and the valve it controls is leaking steadily out of the sliders that the lever controls. This valve is located under the dash directly to the rear of the steering box (manual steering). It looks like the hydraulic inlet to this valve is a cast pipe about 6" long that attaches to the top of the transmission housing to the right and a bit forward of the valve.
I do not need the remote hydraulics and see no problem for me in removing the leaking valve assembly if that might help. I would, of course, keep it in case I need it some time down the road.
The problem:
The three point hitch will lift me (285#) easily from bottom to top, it does not drift down at all and it operates smoothly going up and down. When I attach a 5' bush hog it will start to lift the weight but once it gets so much weight on it the lift arms simply stop, as if a pressure relief valve is activating early. The only oil coming out of the tractor is from the valve mentioned above.
I have changed the transmission oil and cleaned the pickup screen. I have run the three point hitch up and down 100 plus times. This has made no difference in how much weight the three point hitch will lift. I cannot find any information as to where the pump, rockshaft controls or pressure relief valve (if it has one) are. Can anyone point me in the right direction or to a good servicing dealer somehwere near Cincinnati Ohio?
Joe Stewart
03-10-2004 05:41:56
 Re: 2010 Hydraulics Question in reply to Dave / Believer45, 03-09-2004 13:17:49
I don't even know the basics of my 2010's hydraulic system. What I do know, however, is that I cleaned that wire mesh hydraulic filter no fewer than three times, each time soaking it in carburetor cleaner for an hour, and my three point STILL wouldn't lift. I saw a post in the archives that recommended buying a new filter from John Deere ($60). I put in that new filter and since then have had no problems with the three point or the power steering. Give it a try. Joe Stewart
luckydog
03-09-2004 15:42:54
Dave- The hydro pump is right behind the clutch. You have to get under the tractor in the middle and take off the inspection cover. The pump is right in front of the tranny below the shaft. Just worked on a 2010 and the leak you talk about is what I just fixed, turned out to be just o-rings under the cap of the remote. Just remove 4 bolts and there you are. If more serious then you have to go deeper. I think the rockshaft control is between you legs (remove cover) and under the seat. Have not been there but by looking, it is a guess. There is a 1inch plug right above the top link of the three point hitch witch i think you can adjust for pressure or for the 3pt hitch. I have a tek manual in the shop and I would have to read up on this because one thing about it, you will be alot smarter when you are done than you are now!!! Tough one to work on. Hopefully someone else will give you a more gifted ansere than I. luckydog
