4020....instrument panel question
Bo in Maryland
03-09-2004 12:59:13
.....what is the purpose of the little pipe that sticks out of the instrument panel?..... .it's about 1/2" in diameter, L-shaped, points down and has a knurled cap that screws on the threaded open end.....the cap has a little safety chain to prevent loss..... one man told me the pipe was to spray ether in for cold weather starting..... is this right?.....
..... .I'm still thinking about a 4020 that I didn't bid on Saturday..... it only had 5000 hrs and the little pipe still had it's cap and chain which surprised me..... I took that as a possible sign that the previous owner had paid attention to little details..... .
Good luck to all!
Bo
Bob
03-09-2004 14:30:44
 Re: 4020....instrument panel question in reply to Bo in Maryland, 03-09-2004 12:59:13
Keeping the cap on is not just a matter of "little details" on a working tractor. With the cap off, suction from the intake manifold will pull dust into the engine, and even with the tiny steel line, you don't want this to happen!
TB SCOTT
03-09-2004 13:12:35
Yes it is for ether injection. You take the small white nozzle off the can of ether and push the can up into what you call the pipe. Do this only while engine is cranking. Pretty common to see the caps still on it.
