Gas 303 engine for a 4020?
Paul Helinski
03-09-2004 08:40:01
Hi Everyone. I have an interesting problem. I bought a tractor from a guy in Maine through this website and it turned out to be a lemon. Oil had never been changed and it had a pretty bad knock. Turns out to make it right my local JD place wants 5k to rebuild the engine. I posted it to sell it on ebay (I really don't need that much tractor anyway) and it didn't sell so I'm probably going to fix it. I was told from someone on ebay (who uses this site extensively) that he was told a 303 from a model 95 combine will fit if I use my manifold. So I posted an add here for one, but then I was emailed several pieces of advice that it was a model 105 combine with a 404 that I need. My JD guy here confirmed that the diesel is a 404 but said the gas is a 363 (or something like that) and not specifically a 303. If there is anywone here who has dealt with this I would greatly appreciate some help. Spring is here and I really do need a loader and my 2510 ain't got one. thanks. -ph
Steven
03-09-2004 15:02:24
 Re: Gas 303 engine for a 4020? in reply to Paul Helinski, 03-09-2004 08:40:01
If your 4020 is a diesel it has a 404 ci engine. If it a gas or LP gas made from 1964 to 1969 it has a 341 ci engine. 4020 gas made from 1969 to 1972 has a 360 ci engine. The 404 diesel or 341 gas was used in the 105 combine, not in the 95 or 55.
WTW
03-09-2004 10:43:24
Paul, The 303 engine is a Dubuque built engine and was used in a 4030 Gas. This tractor is a whole different cat than a 4020. No the 303 will NOT fit your 4020. The 362 (Waterloo built) Gas is what is in it now and if you wish to convert it with a 404 diesel you will want the version from a 105 or very early 7700 combine. A later 404 engine as used in the 30 series tractors will and can be made fit in your tractor but requires more modification than the older 20 series 404 engines. The 30 series engines are more plentiful and cheaper to purchase. If you want a 30 series 404 let me know I have two for sale one with and one without a turbo can give you all the details if you are interested. Dave W. PS I am a 25 year JD technician and do these repower jobs for hobby work.
