For Buckeye Al (37A)
Leo
03-09-2004 05:23:36
Hello Al!!
Al , I adjusted the clutch as you instructed , it only took half a turn of the castle nuts .
thanks a lot Al !!.
By the way,Is there a clutch kit that I can buy somewhere? I took off the castle nuts and noticed that the friction disk ( looks like a big "O" ) is cracked.I put it back in, and the tractor runs like a champ . but I am afraid it will eventually need replacing.
leo
buckeye al
03-11-2004 15:56:38
 Re: For Buckeye Al (37A) in reply to Leo, 03-09-2004 05:23:36
Sorry fro this not so prompt reply. Glad your adjustment went well.
As for a kit.... None that I know of. Each part is (or has so far always been ) available from my Deere Dealer.
As for the cracked disc.... DEFINITELY replace the disc! It is a safety issue. If you leave the tractor seat but do NOT shift to neutral and if that disc should crack again, the now broken off piece can wedge itself between the rest of the disc & the clutch driver or pulley (depending on which disc broke) and the tractor will move like it or not! For this reason alone I never leave the seat without first shifting to neutral. If this should happen while you're in the seat, the tractor is not likely to stop no matter how hard you pull on the clutch! You're likely to have to stall it or throw the transmission into neutral to stop moving! In a low gear stalling it may be rather a challenge. A cracked clutch disc is an accident waiting to happen with these tractors!
Take care!
