4440 load control yoke
mikeinWA
01-22-2004 22:48:25
Freind is in a bind. Described a situation caused by manure spreader problem which sounds like it broke load control yoke on 4440. I am not familiar with this model I own an old 3020 and his description of the broken part fits the description of the yoke that actuates the shaft on my 3020.(load control shaft etc. if memory serves) Does the 4440 have the same system and if so how do I help him find a replacement? Has anyone had any success welding this part? If you do weld it just how careful do you have to be with alignment to gaurentee that the system will function correctly?
david val
01-22-2004 23:57:13
 Re: 4440 load control yoke in reply to mikeinWA, 01-22-2004 22:48:25
yes, it's principally the same as 3020. probably can find one in a scrap yard. if welding doesn't cost too much it can be tried.
david
