Connecting rod shims on 36 B
Rudy in Tx
03-08-2004 19:13:30
How many shims can you remove on a connecting rod? I have one journal that is out of round and needs to be trued up but will need to take almost all of the shims off to put the connecting rod back on with 2 to 4 thousands clearance. Thanks for any info.
Clooney
03-09-2004 03:31:12
 Re: Connecting rod shims on 36 B in reply to Rudy in Tx, 03-08-2004 19:13:30
Rudy, be careful if you have that crankshaft turned then just remove rod cap shims to compensate for the reduced diameter.. When you remove very many rod cap shims it only reduces the rod bearing diameter in one direction so that leaves a very small bearing to journal contact area.. That does two things: First is places a great loading on a very small bearing contact area & secondly you will get a fairly fast bearing wear as that soft bearing babbit wears into the crankshaft.. If you are already down to few or no shims you won�t be able to adjust it any more. Or it could also burn through the babbit.. A lot depends on how much you have turned off the crankshaft & how much bearing babbit remains in the rod & cap.. You might look into having your rods re-babbited to the new crank journal size while you have it apart�
[email protected]
Bguy
03-08-2004 20:37:08
Rudy in Tx, You can remove all of the brass shims if you need to. There is a steel backing plate that should stay.
