70D Endplay
es
03-08-2004 17:27:53
third party image
Continued from the previous page.
I pulled all of the parts from behind the flywheel today. I posted a picture of what I have found. From left to right is the thrust cover, shims, thrust washer locator?, thrust washer, spacer?, and thrust plate. What happened to the other thrust washer? It must have gotten crunched up?
So all I need to fix this is another thrust washer and then adjust the end play with the shims?
Ken
03-08-2004 21:59:09
 Re: 70D Endplay in reply to es, 03-08-2004 17:27:53
Es,
Check the key on the crankshaft because the very end of the key engages the trust plate to make it turn at crankshaft speed. If end play was excessive for a long enough time the thrust plate could have disengaged the key and "ground" it down to the point where it won't engage the plate when you put it all back together properly. If you need to replace the key, then things get a little more in depth. If it comes to this then contact me and I'll advise you about something else that you should look at. Ken
es
03-09-2004 03:30:23
 Re: Re: 70D Endplay in reply to Ken, 03-08-2004 21:59:09
Which key are you talking about? I see a keyway on the thrust plate, but I don't see anywhere where a key would go on the crankshaft. Are you talking about the key holding the camshaft gear on?
Thanks
es
03-09-2004 03:45:33
 Re: Re: Re: 70D Endplay in reply to es, 03-09-2004 03:30:23
On the last sentence of my previous post I meant to say crankshaft gear.
Ken
03-09-2004 10:15:14
 Re: Re: Re: Re: 70D Endplay in reply to es, 03-09-2004 03:45:33
ES,
Yes,it's the very tip of the crankshaft gear key that drives the thrust plate. If there isn't any key protruding beyond the gear for the thrust plate to engage, it is probably ground off. Ken
es
03-09-2004 13:07:29
 Re: Re: Re: Re: Re: 70D Endplay in reply to Ken, 03-09-2004 10:15:14
The key has been ground off. To fix this I guess I have to remove the timing cover, remove the gear, then replace the key or is there a simpiler way?
Ken
03-09-2004 22:10:10
 Re: Re: Re: Re: Re: Re: 70D Endplay in reply to es, 03-09-2004 13:07:29
ES,
Yup, you got it. The timing cover gasket is no longer available from Deere but Greg Stephen has got them. If you don't have a service manual for a 70d, I suggest you get one. The whole procedure is covered in it. While you've got the timing cover off, check out the camshaft idler gear assembly. The bearings aren't stout enough, allowing the gear to wobble and wear both the idler gear and the cam gear. If this is the case and you decide to replace the gears, consider using 720d or 730d parts, for they were improved.(I used good 70d parts on mine, but someone told me that 720d or 730d would fit. Ken
Clooney
03-08-2004 17:35:15
ES, when the end play gets excessive that allows the thrust washer(s) to come out of position & when that happens they can get broken & ground up.. Look at your earlier post, Frank posted a good adjustment procedure there..
[email protected]
