720 shifting problem
Ken
03-08-2004 17:00:38
A guy I work with has a 720 that won't shift into any of the gears on the reverse side of the quadrant. Is there an adjustment for the shifter from one side ( hi to lo) to another? I'm wondering if that is not going far enough to shift to the other side completely.
Clooney
03-08-2004 17:28:04
 Re: 720 shifting problem in reply to Ken, 03-08-2004 17:00:38
Ken, we need a little more information?
~Does the shift lever move through the bottom quadrant slot & into the L/H [rev] side of the shift quadrant? If the lever does move to the L/H side will it even try to go into any of the slots? Does the trans go into neutral of does it stay in a gear even with the shift lever in neutral?
~If you can get the answers to these questions we can maybe pin point the problem a little better..
[email protected]
Ken
03-08-2004 17:34:36
 Re: Re: 720 shifting problem in reply to Clooney , 03-08-2004 17:28:04
Thanks, Clooney, I'll print this and take it to work tomorrow and find out.
