4630 Powerless
Jd Guy 03
03-08-2004 13:39:17
I have a 4630 that is extremely gutless, the engine is in good repair, and I am told that it is fuel system related, how can I fix this. I do not want to spend a lot of money. Thanks
JDBert
03-09-2004 06:47:53
 Re: 4630 Powerless in reply to Jd Guy 03, 03-08-2004 13:39:17
Does it smoke alot, especially under a load? If it does could be your turbo going bad.
david val
03-08-2004 23:53:22
check the tubing from intercooler to aneroid for leaks. if there is a leak, the pump will not 'open up' by the boost pressure and a lot of power will be lost.
david
David M.
03-08-2004 18:40:17
You need to take the injection pump off and take to factory authorized shop and have pump updated to 4640 specs on low end.
Del
03-08-2004 14:46:55
Frist I would check the fuel filters. A couple of drops of water can sure mess things up. Next I'd check the air filters. They can sure cause problems.
Brokenwrench
03-08-2004 15:14:23
 Re: Re: 4630 Powerless in reply to Del, 03-08-2004 14:46:55
Check the shut off cable,and make sure the lever on the pump is is going all the way foward when the cable is pushed in. It only takes 1/4" back from full foward to hold the rack at partial fuel,which makes it run like an International.
JD Guy 03
03-08-2004 15:18:49
 Re: Re: Re: 4630 Powerless in reply to Brokenwrench, 03-08-2004 15:14:23
The fuel filters are ok and the shutoff is right adjustment. I would like to know how to adjust the pump and aneroid.
Brokenwrench
03-08-2004 15:28:27
 Re: Re: Re: Re: 4630 Powerless in reply to JD Guy 03, 03-08-2004 15:18:49
What is the tractor acting like to say it's gutless. Its real easy to overfuel that engine,It's just about at its limit at factory settings.Most of them I've dynoed run around 175 at stock settings. They overheat easy enough in stock trim,without putting more fuel to it.
