Belt Pulley Bearing Problem on D
JC
03-08-2004 12:45:16
Problem - This bearing assembly on my "D" is bad and needs replacing. The inner race which rides on the crankshaft is a loose fit, about .001" to .002" of play rather than being a tight fit or a tap-on fit. I have been told to lock-tite it on so that it doesn't rotate on the crankshaft and wear it more.
Question - what type of lock-tite do I use, keeping in mind that I may need to remove the inner race sometime in the future.
Thanks in advance for your advice!
JC
Clooney
03-08-2004 12:52:18
 Re: Belt Pulley Bearing Problem on D in reply to JC, 03-08-2004 12:45:16
JC, I would use Loc-Tite 680 retaining compound.. That stuff has a shear strength of 4000 psi & is good to a little over 300�F.. I use that 680 a lot & have always have very good luck with it.. Clean the race & crank with lacquer thinner or brake clean & rough the surface up with a Scotch pad first...
~It will actually come back off pretty easily if you heat it above 300�F with a torch..
[email protected]
JC
03-08-2004 14:07:43
 Re: Re: Belt Pulley Bearing Problem on D in reply to Clooney , 03-08-2004 12:52:18
Thanks Clooney!
I'll pick up a small qty at the bearing place.
Your advice is appreciated.
JC
