4B plow questions
Wind
03-08-2004 05:18:23
Recently purchased what I thought was a 4B, 2-14 plow to go along with my '35B. Will be pulling in light ground, about 30% sand, so feel I have plenty of power to make the dirt turn. My questions are these;
The beam numbers are 582 and 623. According to the GM plow mania atricles a couple of years ago, a 4B should have 582 and 583 as the beam numbers. doing a little more research, I found no plow with those beam numbers, so do I have a morphodite or did some one break a beam and replace it with one close?
Second question; It is missing a front coulter assembly, all that remains is the shaft down from the beam. Does anyone have a parts breakdown so I can ask for the exact numbers? I did some looking on JD Parts and the plow does not even come up on the system. Also, does anyone know of a place to get a replacement assembly? Maybe a good salvage yard?
Third question; It has an extra set of coulter like assemblies mounted in front of the share about half the height of the share. Are these some sort of special sod breaker? I was thinking that maybe they were some sort of cutter to make the dirt cover better covering the trash better. Are they a rare attachment?
DaveH 50
03-08-2004 19:32:38
 Re: 4B plow questions in reply to Wind, 03-08-2004 05:18:23
I'll try to help with my limited knowledge on the subject. Your numbers have me a little bit puzzled. The article in Green Magazine listed 583 and 584 as beam numbers - not 582 and 583. GM should have added beam number 623 to their list.
583 - 4A, 4B, 4C, 4D
584 - 4A
623 - 4B, 4C, 4D
I can find no plow that used beam number 582.
I don't have a parts break down for the 4B plow so I don't know if it used more than one style of coulter. Look at the coulter that you have. On the bottom of the yoke that holds the coulter blade there should be a casting number like D673A - at least that is what my 4B plow has on it. If it does I can help you out with the numbers of the rest of the parts if needed. I have an extra yoke with the whole blade and hub assy. but it is missing the clamp that holds it to the shank that you apparently still have on your plow.
The extra coulter like assemblies are called jointers. They were used to help the soil cover better in cetain plowing conditions. I personally don't use them on my plows. I find that the use of cover boards work just as well and I don't have to mess with trying to adjust the jointers properly.
Hope this helps you some. Ask for more info if you need it. I'll try to answer or hopefully some of the guys on the board who really know their stuff when it comes to plows will answer.
Dave
Wind
03-09-2004 06:44:38
 Re: Re: 4B plow questions in reply to DaveH 50, 03-08-2004 19:32:38
Thanks for the info Dave. You are right on the beam numbers, went back and looked at the article last night. I did a history search on the implement forum and found the name of a guy in Dubuque IA, Doug Coates. He specializes in implements. Called him yesterday and he gave me the exact number for the yoke. I looked at it last night, and I have the same number. He is looking through his "inventory" as we speak to see if he has one. He thought it should be no problem.
Haven't decided on whether or not to use the "jointers", will see how it plows both ways I guess.
As for the beam number, does the number change indicate a year of age somehow?
Thanks for all the info.
DaveH 50
03-10-2004 05:21:16
 Re: Re: Re: 4B plow questions in reply to Wind, 03-09-2004 06:44:38
Here's what I have as far as age of plow.
4A - 1934
4B, 4C - 1935-1949
4D 1938-1949
Dave
