110
Larry E
03-07-2004 19:03:12
On a 110 JD what should compression be ?
I put gage on and got 50 psi.Should it have more at cranking speed ?It has compression release and should have 110-120 comp,but is this after it starts.Right now it will not start has good spark and new clean fuel.this happened suddenly,was running good and quit.
Bob
03-07-2004 21:06:19
 Re: 110 in reply to Larry E, 03-07-2004 19:03:12
What engine do you have?
If you have a Kohler engine with ACR, you cannot do an accurate compression test by cranking it with the starter.
Chris
03-07-2004 19:13:44
Haven't worked on alot of 110's but seen my share of lawn mowers. 50lbs seems low. If you screw an air hose in the spark plug hole and put just a few pounds of air in there you can turn the flywheel with a wrench so both valves are closed. This will tell you if your valves are leaking or the head gasket is blown. Don't use much air (maybe 25lbs or so) and make sure you hold onto the wrench very tight or turn it after you turn the air on. Before you do that make sure are getting gas to the cylinder. Fuel filter may be pluged up if it has one on it.
