Bad luck rolling in Mains
woody
03-07-2004 18:09:13
I had a tough time rolling in the thrust bearing and number one. Once all were in the thing was locked. I put standard bearings in a 5900 hour machine. What is my problem and how can I fix. I hate to pull this engine. By the way it is a 466 in a 4240. The crank looks good. everything else is working fine.
Brokenwrench
03-08-2004 15:34:18
 Re: Bad luck rolling in Mains in reply to woody, 03-07-2004 18:09:13
Did you use bearings from Deere or Clevite? I've had problems with some other aftermarket 1 piece thrust mains. How did you roll them in?Why did you put bearings in it in the first place?
woody
03-08-2004 20:15:55
 Re: Re: Bad luck rolling in Mains in reply to Brokenwrench, 03-08-2004 15:34:18
used std FP bearings wear was just at the limits and I had it down to put in sleeves. I had a problem with number 1 and with the thrust bearing in number 5. Why did number one seem so tight compared to the others.
Woody
John
03-08-2004 03:58:07
Its possible that you distorted a bearing during the roll in. Loosen the main bearing caps one at a time to find the problem. Also make sure that each main cap is on the same bearing boss originally came off of and didnt get reversed. The same goes for the rods also. Always put a lite coat of lube on each bearing shell as its installed. Post back with the results.
