Brittle Brake Linings?
Greg
03-07-2004 17:07:31
Hi - Did a search on this and didn't come up with much. Recently, new brake linings and rivets (P/N AB3849R) were ordered for a 1944 B. The new linings were installed using the supplied rivets without incident. Unfortunately, after connecting two shoes together with the springs, and starting to spread the shoes to fit over the adjusting pins and cam, the new linings fractured as though they were made out of slate. No screwdrivers were used, and the failure happened when only in contact with my hands. A few things were noticed. First, the new brake linings have eight holes for rivets, and the brake itself only has six. This means that about two inches of the brake lining is not fastened to anything, and this is where it broke. Would drilling extra holes for the number seven and eight rivet be a good idea? Or, perhaps, does anybody use adhesive to keep the lining in place? The JD Service Manual doesn't call for anything special. The next thing I noticed is that the new linings are very brittle, and will break into smaller pieces with less effort than it takes to break a popsicle stick. They almost turn powderish when fractured. Is this normal? Are aftermarket any different? This has happened to three out of the four new linings. Thank you, Greg.
Greg
03-08-2004 06:59:38
 Re: Brittle Brake Linings? in reply to Greg, 03-07-2004 17:07:31
Thanks, both of you for your input. Mike, you brought up something that isn't evident from looking at the service manual, but I believe you may have brought up something very important. Since it is the brake shoe (the steel part) that only has six holes, and not the lining itself, which has eight holes, this may imply that the lining should be cut shorter for the six hole application. Do you happen to know the length that you cut them to? The linings that I removed from mine almost did not exist, and there is no indication how long they may have originally been. Thanks again!
Mike M
03-08-2004 06:18:56
Greg; The last time I did one of those B's with the short linings I had to saw them off to match the originals so the brake drum would fit on. They were made short for a reason.
Clooney
03-07-2004 17:13:34
Greg, I have noticed that long overhang on some of the aftermarket brake linings.. I always drill, countersink & add those end rivets to support the ends. I haven't ever broken one but I always add those end rivets first..
[email protected]
