JD 3010 WIRING
HAMMER
03-07-2004 15:22:59
A FRIEND HAS A 1961 3010 DIESEL AND INSTALLED A 24 VOLT INTERNALLY REGULATED ALTENATOR TO REPLACE THE ORIGINAL GENERATOR.I WAS ASKED TO WIRE AND I AM NOT SURE THE CORRECT WAY TO GO ABOUT. IT STILL HAS A 24 VOLT STARTER AND IS POSITIVE GROUND. ANY SUGGESTIONS. IM STILL KIND OF SCRATCHING MY HEAD.
Jaketh
03-09-2004 20:34:33
 Re: JD 3010 WIRING in reply to HAMMER, 03-07-2004 15:22:59
Well,there is one way that might work... If your new alternator is grounded to the case like Clooney and John T suggest it may be.... then hook that up and connect one of the isolated starter terminals to chassis ground (but I do not know which terminal) and rewire the battery cables so the chassis ground is not between the batteries, then you will have a 24 volt system, however you will also have to install 24 volt lights IF you can find any. Well, just a thought..... Happy wiring.
HAMMER
03-11-2004 19:07:24
 Re: Re: JD 3010 WIRING in reply to Jaketh, 03-09-2004 20:34:33
Thanks for all of your help. I think I can take it from here. The reason I couldn't figure it out the first time was because the case of the alternator IS grounded and I had way too much "help" at the time. I think it would be best to switch it over to 12 volts. Does anyone disagree? Happy pulling and God Bless. HAMMER
John T
03-07-2004 16:48:33
Hammer, the old generator was a 2 wire isolated from case frame ground 24 volt unit. The new alternator would also have to be a 2 wire isolated 24 volt unit, is it????? ?? The tractor used case frame ground for A and B (one from each battery) 12 volt battery circuits to feed 12 volt lights etc. Also, on the old Voltage Regulator, it was used a connection points for certain wiring, and the feeds wired to it will have to be replaced accordingly. You will have to have the original wirign diagram and understand the circuitry and then use a case frame isolated alternator and wire from there. I would be afraid to advise you over the net as this may be a lil complicated and I dont want you to fry anything.
Sorry, Good luck n God Bless ya
John T
Clooney
03-07-2004 16:20:22
Hammer, as Jaketh said you have a problem there & I'm not sure how you are going to pull it off.. The original 3010 had a 24 volt starter & generator with 12 volts running everything else [3 separate systems,, a 24 volt starting & charging, a 12 volt positive ground for 1/2 the lights & accessories & a 12 volt negative ground for the other 1/2 of the lights & accessories]..... .. What that means is BOTH the 24 volt starter & generator were electrically isolated from the 12 volt tractor chassis, engine & frame.. Unless that 24 volt alternator is electrically isolated from it's case [there's a good chance it isn't] it just won't work on that 3010 24V/12V-/12V+ system.. If it isn't an isolated alternator you will have to find a way to rubber mount & rubber contain it so it in NO WAY touches the engine or frame.. If it isn't an isolated alternator you will end up with a direct short to ground on 1/2 the system [not a good thing]...
~If by chance that alternator is an isolated ground alternator then it can be wired in like the generator was wired by making sure the polarity on it's output terminals are matched to the tractor's battery polarity.. You could probably just wire to the production regulator as that will make a good connection point just but not use the field control in the regulator...
[email protected]
Jaketh
03-07-2004 15:51:41
Oh are you going to have fun!
If you look again, you will notice one battery is positive ground, the other battery is negative ground. The starter and generator winding are isolated from ground and connected to the ungrounded terminal of each battery (24 volts accross those ungrounded terminals. All the lights and electrical loads are connected between ground and either unground terminal of a battery. (12 volt). Half the lights and load accross one battery, the other half accross the other battery. Well..... I'll let the others help you from here. If I was nearby I'd come help you.
