4520,Burning too much fuel
Williet
03-07-2004 14:57:20
I just bought this tractor , and I think that it burns too much fuel because I believe someone has turned up the fuel,and was wondering how you turn the fuel down in the injection pump.It has a 404 engine with a Roosa Master injection pump that runs off the camshaft.Also wanted to know what the fuel tank capacity is.
DON
03-08-2004 07:20:01
 Re: 4520,Burning too much fuel in reply to Williet, 03-07-2004 14:57:20
THE ONLY TIME IT GETS THE EXTRA FUEL IS UNDER LOAD WHEN THE GOVERNER CALLS FOR IT. CHECK THE GALS. PER ACRE. ALSO MIGHT RUN THE INJECTORS. DON
Mike w J
03-07-2004 16:56:21
I had a 4620 if I burned no2 stove type fuel it took 12.5 gal per hour when I used fieldmaster it took about 9 gal at 145HP I don't remember how big that tank is but it would not run as long as a 4440 with a 65gal tank
