JD # 52 Plow Lift Problems
Lance
03-07-2004 12:24:30
I have a JD 52 plow ( at least I think it is has 612 and 613 stamped on top of the beams). When I engage the lift lever at the end of the furrow it will sometimes lift all the way to the top and lock in transport. Other times it will start to raise and then drop back down, then start to raise and drop back down. Any way to fix these? I trieded tightening the spring inside the clutch housing but no to no avail. Normally, (being the farm boy that I am ) I would think that grease in there would be a good thing, should it maybe be cleaned? Roller inside looks to be in good shape. Any help would be great! Thanks
Tye
03-07-2004 18:12:45
 Re: JD # 52 Plow Lift Problems in reply to Lance, 03-07-2004 12:24:30
Lance, I have a 52 plow and it had the same problem. I had to invest the money and get a new lifting/trip mechanism. It was the only way I could get it to work because of the wear on the inside of the hub. My email is [email protected] if you need more help. --Tye
Bob Collins
03-07-2004 13:19:07
Lance, Not too much to go wrong with these things, but when it does it acts either like yours or dropping in at the start of a furrow, it drops and raises right back up. My experience has been thast the "trip" lever is not returning quickly enough for the dog to engage the next function. This also happens until the operator learns NOT to pull the rope and hold it, just pull to trip and let go. It sounds like you have been inside, if everything looks good being clean and a bit of lubrication should be all it needs. One internal spring is to return the trip lever and may be tightened by turning the bolt clockwise but never turn it back because the spring may detach. An operators manual explains all this and one for most any enclosed clutch plow will give the same info. I've heard guys say do not grease these, but I think you have to find out what actually works for yourself. Good luck. Bob
