Carb adjustment on JD A
GT
03-07-2004 12:18:11
I sent the carburetor from my 1949 John Deere "A" to a carb shop specializing in John Deere 2 cylinder tractors (advertized in Green Magazine & 2 Cylinder magazine). I put the carb on the tractor and it started just fine with the adjustment set from the carb shop but if I increased the throttle, it would run rough.
I have tried changing the adjustment on both the low and high idle screws but haven't found the best setting. When I increase the throttle, it runs rough, backfires sometimes, and will even quit sometimes.
I think I need to start all over again. Where is a good setting to get the tractor started and where do I go from there?
Also, would it be possible that I have an ignition problem with the magneto?
GT
03-07-2004 22:30:46
 Re: Carb adjustment on JD A in reply to GT, 03-07-2004 12:18:11
Thanks Clooney and John T. for the info. Will work on it this week if I get a chance and post a message back asap.
Clooney
03-07-2004 17:16:41
GT, you ask?
Quote: "Where is a good setting to get the tractor started and where do I go from there?"...>>> Answ, start with the idle needle set to about 2 turns out from seated & the load needle set at about 1 turn out from seated.. That will probably be just slightly rich but is a real good starting point.
Quote: "Also, would it be possible that I have an ignition problem with the magneto?"...>>> Answ, sure it's possible but a mag problem usually also causes starting problems.. To test for a spark problem take a old [known good] spark plug, then open the plug gap to 3/16" [use a 3/16" drill bit as a gap gage] , then install that 3/16" gap plug in one plug wire at a time & lay on the engine block, then crank the engine over.. If you have a good spark you should see a bluish colored spark jump that plug gap multiple times in a row.. If you get a nice bluish colored spark to jump that 3/16" gap your mag & wires are probably working ok..
~You should also do a fuel flow test to make certain you have adequate fuel flow to & through the carb [lack of fuel flow could easily cause your problems]...To do a fuel flow test,, just open the float bowl drain cock on the bottom of the carb bowl & make sure you are getting a pencil sized stream of fuel flowing for at least 30 seconds [don't let a high rate of fuel flow for a few seconds fool you it must run it for at least 30 seconds to really tell what your fuel system is doing.. If your tractor has a 3-way fuel valve make darn sure it is turned correctly if that isn't properly set it can really restrict fuel flow.
~Your saying,, Quote: "if I increased the throttle, it would run rough" tells us you either have a fuel flow problem, or a still have a carb problem, or there is something wrong with your ignition system, or you have a worn cam or you might even have coked up valve heads that are restricting the head port flow.. Does putting the choke partially back on help your rough running problem? If so suspect you still have a carb problem.. If choking doesn't help suspect an ignition or other problem..
~You might want to run a hot compression test as a burnt valve can really effect engine smoothness & rough running at the higher throttle settings..
~I don't know what you have available to you but the way I usually attack a problem like yours is to substitute a known good carb, then a known good mag from a good running tractor.. You might also try running with the air cleaner disconnected to see if you are fighting a plugged air cleaner inner mesh but a plugged air cleaner usually makes them run rich & blow black smoke out the muffler..
~Other things to look for.... Make sure you are using solid metal core spark plug wires [carbon core TVRS automotive plug wires are the kiss of death on a 2-cylinder mag system],, make sure you have good hot compression on BOTH cylinders,, make sure you don't have a crankcase full of gasoline [sniff the oil],, make sure the spark plugs are new [tired or partially fouled plugs could easily be your problem],, check your points gap [improperly gapped points on a mag system can cause a spark problem under load,, check the mag cap & rotor for problems like carbon tracks or cracks & make sure the mag shaft bushings aren't worn & loose..
~Your problem could be about anything so about all you can do is try to work your way through the carb, ignition, & fuel flow areas & try to isolate the problem area..
~Any questions just post back here or E-Mail me directly & I will help you find & isolate your problem....
[email protected]
John T
03-07-2004 17:04:57
GT, if carb adjustmetns didnt help and youre sure the carb is good (and float level set proper), you may have an ignition problem (weak spark or out of time) or possibly a vacuum leak or insufficient gas flow getting to the carb.
1) To check for vacuum leaks at idle, spray WD 40 or Carb Cleaner or an unlit propane torch all around the manifold base and where the carb mounts and if she speeds up and smooths out, you have found a vacuum leak causign poor idle.
2) To answer your question, A good place to start is for the load needle closed then 3/4 to 1 turn out and 1 3/4 to 2 out for the idle.
3) Make sure the air cleaner bowl is clean and water freem and you have fresh clean water free gas.
4) To check flow to the carb and through its needle and seat and side inlet strainer, turn gas n and open carbs lower drain cock/plug and insure a steady gas stream approx 1/16 inch flow good a minute or two. IF NOT POST BACK, you gotta have good flow to the carb for it to work right. I trust its float level is not too low????
5) Make sure BOTH plugs are producign a good visible blue and NOT a faint thin wimpy yellow spark. What kind of mag you have????? You gotta have a good visible BLUE spark, do you now????? ????? ? If not, post back for spark troubleshooting tips (long n detailed)
6) Have you checked the timing????? ? If its way off, she can run bad and not take up her gas when you crack the throttle. MAKE SURE ITS RIGHT AND YOU HAVE A GOOD BLUE SPARK.
Theres plenty more, but check these things first and post back. ALSO NOTE be sure the plugs are clean and NOT fouled and the points are gapped correct and free of carbon or burning or pits. THOSE THIGNS CAN CAUSE YOUR SYMPTOMS IF THE CARB AND FUEL ARE ALL OKAY.
Check simple easy thigns first like clean water free gas,,,,, ,,adjust needles,,,,, ,,, no vacuum leaks,,,,, ,,good gas flow out carbs bottom,,,,, ,, fresh plugs and good proper gapped clean points,,,,, ,,,, and timing.
Lemme know, God Bless
John T
