1965 John Deere 4020 Diesel Starter
Chuck
03-07-2004 07:58:29
Subject: 1965 4020 Diesel 24 Volt Starting?Starter Problem Name: Chuck Date Posted: Mar 7, 04 - 8:29 AM Email: [email protected] Message: I've had the tractor about 2 years and it's been fine. Beginning a short time ago it started right up as usual on the very first try. I would use it for a while and then shut it off, and it would not start(like the battery was week and I think the starter make strange noise). The same thing happened after recharging the batteries-started right up but would not start after some use-that is it wouldn't turn over. Bought new batteries, and cables and the same thing happened--Started in less than a second, ran it for about 5 minutes, shut it off, and then got nothing but a bad grinding noise from the starter which must mean a bad starter, which I am taking off to get it checked out late next week. I think I have a bad starter, and do you agree? Also, if the starter is bad, dose it make sense that it starts instantaneously when the engine is cold but the starter makes a bad noise and I think probbly does not turn the engine over when it's hot. I hope you can help. Chuck
