4020 powershift problem
Wayne
03-06-2004 22:56:18
looked at a '66 model 4020 diesel powershift today. owner is not knowledgable about the tractor or it's history. starts and runs very well, but i noticed a couple of things with transmission and i have no experience with the powershift. when upshifting throught the gears, forward or reverse, there is a hesitation between 3rd and 4th.following hesitation, tractor shifts without slippage. tried shifting directly from 3rd to 5th or 6th and same results. also, park does not hold tractor. is this a major issue, or? thanks for the help in advance guys.
Todd
03-08-2004 16:29:00
 Re: 4020 powershift problem in reply to Wayne, 03-06-2004 22:56:18
Our 4020 had the same problem yours has with the park. I was able to fix it by shortening the park cable. You can do this behind the dash by taking off the hood cowl (I think that's what it's called). It has a threaded end so it can be shortened. Just make sure you don't get it too short. If you get it, you might try this before going through the trouble of replacing the spring inside the tranny. Just my $.02 worth.
GT
03-07-2004 12:26:04
I have a 1965 4020 that had the same problem with "Park". The problem was corrected with a new cable. I may have been able to free it up but thought it would be safer to just get a new cable. The park position on the transmission needs to work correctly.
Also, the shifting on your 4020 may be normal. Ours sounds similar to yours and we have had no problems. They are good tractors.
Mike w J
03-07-2004 08:05:11
The tractor should have a trans. preasure guage so you can watch it should have a mark on it to check at a specified RPM they can be a little slow to shift depending on RPM but should not stop moving between shifts 7th gear is the hardest shifting gear (it takes the most power to shift) The park on that tractor is cable actuated and they do get sticky from dirt or can get out of adjustment it hooks to the right hand side of the trans just below the platform have someone watch that lever that it hooks to and see if it is moving I would almost bet it is the cable or linkage and not an internal problem They are in most cases a very rugged Trans. if not abused by low or dirty oil
Brokenwrench
03-07-2004 07:56:29
Some hesitation is normal depending on how the shift valve is set. You can adjust the shifts for a soft,but somewhat hesitant shift or firm it up to be quite snappy. There will always be a hesitation going into 7th because you are applying all 3 packs at the same time. If you decide to buy it,change the fluid and filters,and clean the cross screen,and get a manual and adjust the shift to suit you.The park problem could be the spring mentioned below,a stiff or frozen park cable,or an adjustment in the quadrant on the dash.
Wayne
03-07-2004 11:10:43
 Re: Re: 4020 powershift problem in reply to Brokenwrench, 03-07-2004 07:56:29
Thanks to all for the advise. park appears to be a linkage issue. 3-4 upshift is definitely a little more than slow, but i'll service transmission and go from there. thanks again.
JMS/MN
03-06-2004 23:30:02
It might be good to get a qualified JD tech to measure the pressures on the clutch packs. Normally there is a more noticeable speed change between 3&4, as well as 7&8, compared to other speeds, but I don't think the hesitation is normal. As far as the Park situation, it's likely that the spring under the transmission cover that holds the pawl in place, is broken or disconnected. Not to worry if it is in the bottom of the tranny housing- just replace it. Many tractors have them laying down there.
B JDfarmer
03-07-2004 06:44:59
 Re: Re: 4020 powershift problem in reply to JMS/MN, 03-06-2004 23:30:02
We have a 4020 powershift on our farm. Its a really nice tractor. Our power shift is a little slow but its how their suppose to be. Now yours my be different since it doesn't shift into park.
Bo from Sweden
03-07-2004 12:52:29
 Re: Re: Re: 4020 powershift problem in reply to B JDfarmer, 03-07-2004 06:44:59
We have had some hesitation in the gearchange, for 25 years, without problems. It also depends on the load and engine speed, if it field work or heavy road transport.
We had the same parking problem, the Park did not lock the tractor. It tuned out to be an internal transmission trouble, there is a Arm with a Roller, actuating a locking claw. This Roller is secured with clip. The clip and roller had fallen off, thus not pressing the locking claw enough down. It was quite easy to fix, after liftng the top of the transmission. JD had a reasonable priced replacement part with a safer cotter pin locking.
