148 vs 158 loader
gorilla
03-06-2004 15:08:27
What is the difference between a 148 & 158 loader? I have been told 10" of reach and 2 1/2 ft of reach. Still lookin...thanks
Brokenwrench
03-06-2004 16:45:26
 Re: 148 vs 158 loader in reply to gorilla, 03-06-2004 15:08:27
Your measurements are pretty close. The 158 is also somewhat heavier built with larger cylinders,and alittle more lift capacity.You want more lift and strength,go to a 168 loader.
Mike Aylward
03-07-2004 10:45:29
 Re: Re: 148 vs 158 loader in reply to Brokenwrench, 03-06-2004 16:45:26
The 168 loader is simply a 158 loader factory widened to fit on the wider chassis of a 4640 tractor. I believe all parts regarding strength are the same. It is no heavier than a 158, just wider across the mounts. Hope this helps. Mike
B JDfarmer
03-07-2004 15:14:10
 Re: Re: Re: 148 vs 158 loader in reply to Mike Aylward, 03-07-2004 10:45:29
We have 3 148 loaders on our farm and they are all a good built loader. If your looking for reach go to a 158 because their arms are longer. If your looking to put it on a 4640 size go to a 168. The 158 and 168 are heavier than the 148 with bigger cylinders.
