Follow-up on noise in JD 40
Mark T.
03-06-2004 08:25:31
Thanks for all of your replies in the string below. I went through the hydraulic lines this morning, tightening things up, and I am convinced that this is the source of the noise. I might have helped it some, but it still is vibrating...and making the buzzing sound.
I'm going to take Frank's advice and change the Touch-o-matic fluid to 10W non-detergent oil. When I brought the reservoir up to level, I used 10W30 oil, and that is when I first noticed the noise.
Now...I can't find anyone that has 10W non-detergent. One parts house agreed to order some for me, but couldn't promise on availability. TSC advised that they have 10 weight oil, but it is SAE-detergent. Is there a good source for the non-detergent 10 weight?
Also, I need a new oil pressure gauge and would like to go as close to original as possible. Anyone know a source for this item?
Peter B.
03-06-2004 18:21:46
 Re: Follow-up on noise in JD 40 in reply to Mark T., 03-06-2004 08:25:31
Non-detergent, 10 wt oil can be had at any oil distributor location. Ask for a Turbin R&O oil, ISO VG 32. This is a 10 wt oil, with a rust and oxidation inhibitor, plus an anti-foam additive included. It is an industrial lubricant, but works great.
Wayne in Tn.
03-06-2004 12:18:33
Mark, my local Wal-Mart and also my small town parts store, has the 10w ND oil. This is the cheap stuff, no brand name.
Johnnyputt
03-06-2004 12:07:38
Oil pressure gauges are available at Deere. If my memory serves me well, they run $40-45.
Henry J
03-06-2004 09:09:47
Mark
Hope that fixes the problem for you. Just another thought, when I took my hyd pump apart I found that one of the bearings was extremely loose in comparison to the others. It would surprise you how economical the bearings are. I replaced them all while in there, but won't have the JD running for Quite a while. It fell back burner to finishing the house.
Can't advise you on the oil source.
