1020 jd
tm in ky
03-05-2004 04:01:22
I have a 1969 1020 JD. It has sprung a leak in one of the metal hydralic lines. The problem i have is trying to figure out how to get this line loose from the back of the tractor. It appears to go straight into a "block". Do I need to remove something to get to it? Cannot figure it out. All i want to do is solder it back but I'm not going do it on the tractor. Any help would be appreciated. Thanks
david val
03-05-2004 08:49:21
 Re: 1020 jd in reply to tm in ky, 03-05-2004 04:01:22
if you mean one of the three lines along the right bottom side of the engine, then the thinner one (1/2 inch), is a high pressure line. do not solder it. you can try to braze it.
the other two (3/4 inch) lines are the supply line that runs from the clutch housing to the hydraulic pump. you need to remove the radiator to remove this line. the third line is the return line that usually runs from the cluch housing to a hose just under the radiator. you can remove this line by losening the hose clamp, removing all line clamps and supports and removing the triangle shaped piece thet holds the lines to the clutch housing.
these lines deliver a much lower pressure (up to i50 psi).
david
mwo
03-05-2004 06:26:41
We just cut the line and pushed in a thick rubber hose with 2 clamps. It stopped the leak fine. Just make sure the hose is rated for pressure.
