Another what is it worth question
Mike in UP of M
03-04-2004 19:34:30
Please help, I need to come up with a fair price for a 1952 Model "A", over all it is in good condition. It starts and runs good and does not smoke. The sheet metal is striaght with good paint. The paint is not new but has a good appearance. It has cast rear wheels and all the tires are in good shape. It has a distributor ignition and water pump. A snow blade is mounted on to the tractor and has tire chains. Thank you for the help.
RUSS
03-06-2004 03:51:17
 Re: Another what is it worth question in reply to Mike in UP of MI, 03-04-2004 19:34:30
JD 52A; LO 1460, MID 2440, HI 3120 TOSS IN 300 FOR THE EXTRAs. 2740 MIGHT BE A FAIR OFFER.
LOTS OF FUN TO FIX, SOUNDS GREAT AND CAN TOOL ABOUT OFTEN. GOOD CHOICE.
Mike in UP of MI
03-05-2004 19:38:10
I would like to thank everyone for there input, it helps me out a lot.
Rob
03-05-2004 17:02:42
Mike- What part of the UP do you live in?
Mike in UP of MI
03-05-2004 19:33:21
 Re: Re: Another what is it worth question in reply to Rob, 03-05-2004 17:02:42
I live about 5 miles north of Menominee. We got about 4 inches of wet heavy snow today. Do you live in the UP also?
2 Cylinder
03-05-2004 15:16:28
It should be worth at least $2500 with what you have listed, and I live in Central Michigan. I sold one (47)last fall for $3500 with a powerblock, set up for pulling.
Rodney A Johnson
03-05-2004 08:04:03
'52 was the only year that JD put water pumps on model As. Also note that only some of the '52s have water pumps.
In my mind the water pump adds value to the tractor both as a collector and as a usable tractor (less likely to overheat on a 90+ degree day).
Many late model As in good shape run around 1500USD to 2000USD in SE MN.
stretch
03-05-2004 06:37:58
The other suggestions are a little low. You indicated it has tire chains. Any of you other fellas bought any chains lately? You should get closer to $2,000.00.
Jericho
03-05-2004 05:38:57
Around here (mid-MI) you'd have no trouble getting $1750 or so for it.
S. D. Springer
03-04-2004 22:41:30
Send me your email address.
[email protected]
Martin J Zielinski
03-04-2004 21:13:38
$ 1200 to 1400 sounds fair to me
MJZ
