Fuel or Gas Pistons Plugs
Randy in San An
10-21-2003 10:38:08
When my 1939 A was rebuilt (just before I bought it), the cylinders were bored and new .090 over pistons were installed. This was arranged through the dealer and done by a shop here in Texas (I don't know exactly where). Is there a way I can tell if these are Gas or All-fuel pistons without doing a teardown? The code on the dealer invoice is MIS090 if that helps.
What plugs should I be using? She has Champions now (which I read here are not so good).
Thanx.
Glen in TX
10-22-2003 14:03:26
 Re: Fuel or Gas Pistons Plugs in reply to Randy in San Antonio, 10-21-2003 10:38:08
Most Deere pistons had a part no. on the inside of the piston. If you have the 7/8-18 plug and the Champion W18 you can use AC C77L or C77 if you can find them. They tell me AC quit making them. For the 18mm use AC C87 , Autolite 377, or Champion D21. I have the W18, C87, & D21 if you can't find them.
Will P
10-21-2003 14:16:58
Deere never made any pistons for the A over .045 over. So, if it has .090 pistons in it, they have to be aftermarket. And I don't know of anybody that makes "all-fuel" pistons, but Deere. So they are probably aftermarket aluminum "gas" pistons.
Will P
