Another problem on my JD 1020 gas!
Pastie
03-04-2004 13:30:19
Can someone help me out on where to start looking for the problem with my JD 1020 hydraulic lift?
It will not move (using the lever control) from about half-way in between all the way up, and all the way down! I can lift the arms up with no resistance. But, I can stand on them and they will not go down. I shouldn't be able to lift the arms up with my hands, should I?
What can I start checking to try and fix the lift?
Thanks very much. You guys are an enormous help with troubleshooting tractor problems.
Pastie
Old Swede
03-06-2004 07:05:22
 Re: Another problem on my JD 1020 gas! in reply to Pastie, 03-04-2004 13:30:19
Pastie, I can lift the links on my 2010 by hand. The only resistance comes from the lift arm springs. The manual only diagnoses lift problems not drop problems, so can't help you anymore than that.
Pastie
03-06-2004 09:04:54
 Re: Re: Another problem on my JD 1020 gas! in reply to Old Swede, 03-06-2004 07:05:22
Swede,
What are some of the diagnosis for lift problems that I might be able to check out?
Thanks.
Old Swede
03-06-2004 16:17:52
 Re: Re: Re: Another problem on my JD 1020 gas! in reply to Pastie, 03-06-2004 09:04:54
Here's the troubleshooting info.
First the obvious, fluid level and leaks. Check system pressure. Listen for pump noises indicating air leaks. It says you don't have a filter, so I guess no use checking to see if it's plugged.
More specifically, here's 3 problem areas.
Lift system fails to raise: Could be caused by improper adjustment of valves, low pressure or faulty hydraulic pump. Hydraulic pump coupling disengaged (2010 only). Lack of fluid.
Lift system will not hold: Improperly adjusted valves or poor seating of check valves.
Noisy pump or valves: Low fluid level, fluid foaming (improper fluid) or air leaks in pump intake line. Plugged filter (2010).
There's a couple pages of disassembly/overhaul info that's too much to type. Let me know if you think of something specific I can send you.
Pastie
03-06-2004 20:29:02
 Re: Re: Re: Re: Another problem on my JD 1020 gas! in reply to Old Swede, 03-06-2004 16:17:52
third party image
Thanks Swede.
I'll start doing a thourough check on the items you mentioned.
I have a picture of the rear of my 1020 to show the position of the arms.
Thanks again!
david val
03-05-2004 00:40:53
try to get an operator's manual. it will help you understand how to operate the hitch. it maybe ok. if not, a step by step adjustment is the first step.
instuctions for adjustment are in the service manuall... but some old timers may remember from experince. post again if you conclude that adjusment is required.
david
Adam
03-04-2004 18:04:33
Did this problem just occur? You should be able to pick the lift arms up like you say you can. There should be an adjustment below the seat on top of the rockshaft housing that control the rate of drop. That could be tightened all the way. But if it will go up and come down part way, that wouldn't be the problem. You shouldn't be able to pick up the arms if it is all the way up. Try hanging something heavier on the arms and see what happens.
Pastie
03-05-2004 08:32:26
 Re: Re: Another problem on my JD 1020 gas! in reply to Adam, 03-04-2004 18:04:33
I bought the tractor a few months ago. The fella that sold it to me had it rigged up with external hydraulic hoses (from the right side of the tranny to the left side) to where the lift would raise but would not lower. I disconnected all of the external hoses and capped them off since I was not going to use them for additional hydraulic implements.
Let me try to explain the problem a little better.
The controls will not move the lift at all. It is positioned about half-way between up and down. Moving the lever does nothing at all. But, I can manually lift the lift arms up to the very top of the travel. But, I cannot force the arms down all the way, even with the control lever in the down position. I was just trying to figure out what I need to check as far as hydraulic problems, leaks, etc., to get the lift to work for mowing.
Thanks.
