37A Cutch
Leo
03-04-2004 12:11:30
Hello boys!!
A quick question on my 37A.
I have been working on some minor details on my tractor , after every detail I take it for a spin. on the last stroll it seems that the clutch is not engaging well because the tractor does not take off as usual , and on a very slight uphill it slows down to a crawl while the rpm remain constant. can the clutch be adjusted?
also I noticed that the front wheels have a bad side to side movement whe the tractor is rolling . I opened the top access to the steeering pinion and it looks like there is some play between the toothed gear and the worm gear .
thanks for the attention guys leo
buckeye al
03-05-2004 14:25:21
 Re: 37A Cutch in reply to Leo, 03-04-2004 12:11:30
Re the clutch.... Remove pulley cover. Remove the three coter pins from the castle nuts. With the clutch disengaged, tighten each nut one castle then replace the cotter pins. Now turn each nut AND THE BOLT counter clockwise until the bolt is returned to its original position. Bit confusing there but depending on the age & use, the tee shaped head of the bolt which you cannot see usually wears an indentation into the cast clutch dogs which you also can't see. When you tighten the nuts, the bolt heads usually climb up out of these indentations and the net change to clutch operation equals the sum of the 1/6 th turn of each nut PLUS this wear! RESET the bolt heads back into the indentations worn into the clutch dogs and you'll have adjusted just one flat. May take a few tries to get the right snap over center but patience will win out.
Good luck. Post back with your results.
