60 power steering-Clooney
Stuart
03-04-2004 09:02:43
My 54 JD60 is foaming oil out the top of the breather on the power steering. I know that there is air getting in on the suction side of the system. I have overhauled the pump and checked for leaks in the lines but have found nothing.When I overhauled the pump that is connected to the fan, there was no gaskets between the parts, just seals on both ends. My question is can I find gasket material that is thin enough to make gaskets for in between parts of the pump, it is metal on metal and I did not use any kind of sealer because Of the fact that it might put more tolerance into the pump and reduce the over all pressure.
Clooney
03-04-2004 11:13:27
 Re: 60 power steering-Clooney in reply to Stuart, 03-04-2004 09:02:43
Stuart, you really should have used sealer between the pump end covers & body.. It's possible you have an air leak there. I have used a very thin coat of Loc-Tite 518 between those surfaces for quite a few years now without any problems. For the last couple of years I have been using 2 part epoxy urethane clear coat paint.. That urethane is thinner & it sets up quite solid.. You really can�t use any type of gasket material there because of the added thickness..
~You might try hooking your vacuum pump [if you don't have one use a Mity-Vac or car manifold vacuum source] to the reservoir filler with a big cork with a hole in it.. Then pull a vacuum in the P/S system,, than take an oil can with a mixture of oil & kerosene in it & go over all the suspected leakage areas.. You just might see it suck that fluid into the P/S system..
~Another thing you could try [I haven�t ever used it on a tractor but have on a car] is to place a piece of clear tygon tubing in the return line between the steering gear & pump.. If you have aeration in that tube you know for sure you have a air leak into the system..
~I had a 520 a while back that had an air leak into the P/S system & found it was the lower pedestal �O� rings allowing air to enter [mostly when the tractor was parked] then when started it would foam pretty good for a while [it took a while to find that one]..
[email protected]
Stuart
03-05-2004 08:35:06
 Re: Re: 60 power steering-Clooney in reply to Clooney , 03-04-2004 11:13:27
I have another question:The 2 bolts that come up from the bottom to mount that pump, are they blind holes in the pump or could oil be running out of there or air getting in? I think they are 3/8 or 5/16 by 1.5in bolts. I hope they are blind holes. Also I did put permatex in between the pump layers the last time I had it off which is the only time I have had it off and it still drips oil from the bottom of the pump. If I had I milling machine and was really talented I could mill a couple of thousandths off each peice and make up for it with a gastket.
