B gas manifold
Andrew
03-04-2004 07:10:55
Just took the manifold off our "B". On the two back stud holes, the casting is broken off towards the back edges. Also, on top of the manifold, there is the same problem. The gasket surface however, is fine with nothing broken. Any opinions? Don't really want to buy a new manifold. Thanks.
52BMAN
03-04-2004 18:27:38
 Re: B gas manifold in reply to Andrew, 03-04-2004 07:10:55
Andrew, I have a used original all-fuel manifold for sale, cheap. Email if your interested.
Karen
03-04-2004 09:32:40
I know of someone that sells a manifold made in the USA and it is very reasonable. Email me and I'll give you his email addy
Tim...OK
03-04-2004 07:18:18
The one on my A was similiar,I built it up with the MIG ,ground it back to shape,then finished it with die grinder,then shot peened it,hard to tell where it was repaired. All that work because I didn't want to support China with a replacement manifold :-)
Tim
Andrew
03-04-2004 08:29:07
 Re: Re: B gas manifold in reply to Tim...OK , 03-04-2004 07:18:18
Tim, thanks for the help. But do you think it would hurt to keep running the manifold the way it is right now since there is nothing wrong with the gasket surface?
Tim...OK
03-04-2004 10:12:43
 Re: Re: Re: B gas manifold in reply to Andrew, 03-04-2004 08:29:07
As long as you got sufficient area for the bolt and washer to hold down on,I see no problem with it.
Tim
