37 A and 47 A transmissions
Paul in Minneso
03-03-2004 20:39:03
Question:
I have a 1937 A and two 1947 A's (one is a parts tractor) I need to replace some (maybe a couple) gears in the 37. As far as I can tell I can use the gears from the 47. Is this correct?
Thanks for your help
Paul
Clooney
03-04-2004 18:34:13
 Re: 37 A and 47 A transmissions in reply to Paul in Minnesota, 03-03-2004 20:39:03
Paul, maybe, some things are the same & others aren't. About all you can do is sit down with a parts manual & compare,, or just compare the actual parts you are trying to swap out. Most gears, bearings & shifter parts have casting numbers on them..
[email protected]
Greengo
03-06-2004 10:51:25
 Re: Re: 37 A and 47 A transmissions in reply to Clooney , 03-04-2004 18:34:13
I ran into that on my 37 A also, some parts will work and some will not. I just took parts needed
to salvage yard and matched numbers. But if you have parts tractor you can do that also.
