3010 oil seal @ steering wheel
Brad
03-03-2004 19:08:23
I have oil leak at steering wheel. Repair manual shows an oil seal near the top. I will replace that but am wondering if I need to do more than that. Hoping that will fix it.
JD 4020, 3020,
03-04-2004 15:27:15
 Re: 3010 oil seal @ steering wheel in reply to Brad, 03-03-2004 19:08:23
I know that on the 4020 which is almost the same thing, the top oil seal right below the steeering wheel is only a "dust" seal and will not solve your problem. Your best bet is to remove the steering control and have it rebuilt. The seal is not the only cause of the leak, or in other words the seal usually does not leak until other parts within the control become worn. If you do this yourself be careful to make sure it is adjusted properly when you are done.
