4020 on steel?
Dan
03-03-2004 15:49:30
I was flipping thru a Nov '03 GM and I'm sure there is a black and white photo in there of a steel wheeled 4020.Seems odd.Can anyone shed some light on that.
The Dukester
03-05-2004 09:46:55
 Re: 4020 on steel? in reply to Dan, 03-03-2004 15:49:30
Curious people kinda-those Amish. Here in So. Michigan there must be two different or more "sects" of them. One group uses tractors only for belt power, appartently they can't even move the equipment they pull with the belt to another location with tractor that runs the belt. But, another group only 20 or so miles away uses their tractors on steel wheels, sometimes with lugs and sometimes with bolted on treads from tires, for anything. Must be they just can't have tires with air in them. They use hard rubber tired buggies too while the others use steel tired wagons and buggies. Funny too, they don't wanna tell you much about this kind of thing. I offered to pull their thresher with my JD G once and the older guy in charge said no chance, they shouldn't even allow the rubber tired tractor in their field.
andy
03-04-2004 21:08:18
The Amish use the steel wheels. Rubber tires are too modern. They drive horse and buggies. The use of rubber tires like on cars, pickups and tractors would let them venture too far away from home. Then they would be exposed to the influence of the outside world. They do use fuel power machinery although. Gas and diesel. Large population around Kalona, Iowa. Many, many John Deeres and yellow Cases with steel. I have seen 4430's on steel. Grinder mixers, plows, wagons, disks, mowers have all been converted. Around Kalona they do use the power to pull implements. No electricity. Although they will use gas or diesel power refrigeration units, gas to air powered power tools, gas to vacume milkers, etc. They will ride in cars if necessary. Also last fall there was some reason that the Amish had to chop silage (either a drought or time constrants) and an Elder in the church allowed the use of rubber tired equipment in that emergency to get the work done. I believe that was out east somewhere. They are very religious people. They work in ways most of us wouldn't even think of doing.
Adam
03-04-2004 09:59:44
Near Yoder, KS there is a group that can not use pnumatic tires on their tractors. I have chatted with them many time. Their church prohibits the use. So they make their own steel wheels for tractors, round balers, hay wagons, etc. They put 2 old used tires on the steel wheels of rear tractors. One bolted to the wheel and the other floats over the first. He quoted me $4500.00 for a set for the rear of my 1030 case last fall. They sell them to people who cant keep tires on their tractor, like for mowing rough pastures, etc.
ABW
Nate in IA.
03-03-2004 19:12:12
Saw an 806 IH in Amish country about 15 yrs ago on all steel. Also the Badger silage wagon on all steel was too.
Chris
03-03-2004 18:41:25
Hey take another look i think it says they used those wheels in the factory. I think that one in the pic is getting painted. Chris
hardscrabble
03-03-2004 18:04:12
I once saw a picture of an IH 706 on steel. It was equipped that way to handle stalks in a cane field, which apparently were too brutal for rubber tires.
Dave Baco
03-03-2004 17:34:33
Look in many parts manuals also for steel option. I was told Meninites helped keep the steel on the assembly line. I know as late asCase 830's had that option also. Dave NE Iowa
Mguy.
03-03-2004 17:28:57
Probably Amish. Mguy.
Soldeir Tom
03-03-2004 17:47:05
 Re: Re: 4020 on steel? in reply to Mguy., 03-03-2004 17:28:57
Beg to differ with you MGuy, with the exception of the "fender Amish" up in Lancaster County PA, an a few others probably, Amish folk won't use a tractor for "traction" only for pully power. Least ways, that was what I saw while stationed up in PA right by Lancaster county for two years. I believe the Menonite brothern would more than likely contribute more to the staying power of the steel. Of course I am FAR from an expert on that, and probably should keep my opinions to myself, but if we all did that, there would be no discussion boards, only boards with a documented fact stated for others to read, right? I'm gonna hush now,
~Walk in peace~
randy hall
03-04-2004 16:30:05
 Re: Re: Re: 4020 on steel? in reply to Soldeir Tom, 03-03-2004 17:47:05
some sects of mennonites use tractors with steel wheels. about forty miles from us these farmers have some brand new deeres with steel some are even mfwd. they make them themselves and they do a great job building them they look like they could be factory equipment. they use rebar for the lugs.
